Runs like a Deere, does not steer worth a hoot
发表于 2021-8-31 23:40:59 | 显示全部楼层 |阅读模式
1/2 round of slack in steering wheel. Sector shaft has 3 bearing surfaces, the 2 closest to the teeth were pitted (bad case of rust worms). The bearing surface nearest splines was good for use. Steel backed bronze bushings were worn and one in end cap was worn through. Welded piece of rod to t-slot end of sector shaft to machine a good center. Under cut the journals .030 and did not nearly get to bottom of pitting. Instead of cutting pits out ( looked to be quite deep) I opted to weld over area. I knew there would be some porosity but decided it would be OK in this situation- tractor. I wouldn't do this for a road vehicle. New shaft would be only option.Tig shaft with ni99 because, rust worms do not eat it, good bearing surface, cuts nice, had some. Preheated shaft to 600 degrees, let it cool in still air.Installed some steel backed nylon bushings, bored seal area for standard seal, reassembled, sprayed some rattle can color, reinstall on tractor. I'll put rest of tractor together Monday.Peter Attached ImagesEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:last pics Attached ImagesEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:Wow, it looked like a total loss. You make these repairs look so easy. Great work once again.
Reply:Great looking repair job, looks good as new.  Shows what you can do if you have the initiative, skill and equipment."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Beauty! Thanks for posting it.Ask 'em to at least throw a bucket over the steering wheel to shed some of the rain water. Good Luck
Reply:Originally Posted by forhireWow, it looked like a total loss. You make these repairs look so easy. Great work once again.
Reply:Another masterfully superb job Peter. Now it not only runs like a deer, it can change directions like one too. Last edited by duaneb55; 02-26-2011 at 10:12 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yeah we get all the fun jobs..Looks like new!That must be the small shaft you mentioned  you did with your positioner.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It's strange how little things like this require so many steps and total work to save. It's definately for people who love to do it...Nice save Peter!Matt
Reply:Originally Posted by duaneb55Another masterfully superb job Peter. Now it not only runs like a deer, it can change directions like one too.
Reply:Originally Posted by denrepBeauty! Thanks for posting it.Ask 'em to at least throw a bucket over the steering wheel to shed some of the rain water. Good Luck
Reply:Originally Posted by TractapacTop job (again!) Peter.Denrep's idea is a good'un.I have a similar problem with a Case-IH tractor where the cap in the centre of the steering wheel allows water into the hub and when enough gets in, it goes on down the steering mechanism. I haven't had steering box problems but the nut holding the steering wheel rusts badly. I took an easier option and drilled holes through the composite boss to let the water out. It still holds a little but never gets high enough to touch the nut or go past the star washer and down past the woodruff key. The mate I bought it off never kept the nut on the steering wheel hub, called it a security feature, as if he to needed leave it anywhere dodgy, he could pull the wheel off and throw it in the back of his Ute. However it's got a large post rammer on the back of it and when I first started using it, as I went up an incline, the rammer swayed back, causing the tractor to tilt back a little. I gripped the wheel a little harder and the wheel came off in my hands. I though all my Christmases had come at once! Next action was to fit a new nut. It was after this that he explained his "security measure" with a chuckle.
Reply:Originally Posted by castweldThanksThats a good story about security measure, I usually leave with battery, disconnect ignition.The steering wheel on this 950 was plastic with aluminum hub cast in plastic and steel shaft. Thought I was going to brake it trying to get it off.Peter
GMT+8, 2025-12-25 09:41 , Processed in 0.070563 second(s), 18 queries .
