Floor joist brackets
发表于 2021-8-31 23:40:59 | 显示全部楼层 |阅读模式
A little project I got to weld this week after hours. Lots of welding. The plates were all punched and cut, all I had to do was fit up and weld. Kind of project I like, wish I could have one every week like it. Attached ImagesGood judgement comes from experience.Experience comes from bad judgement.
Reply:That floor is not going anywhere.  ...I think Samm might need a few....City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:looks good hood time can be great just tune out the word and burn rod.What mat / thickness process and settings?Thanks
Reply:The material was 1/4" steel, .035 wire, Airgas tri-mix CO2, argon, and oxygen. Couldn't tell you the amps, it is number 3 on the dial of a millermatic 210. They just went out the door, now I can clean up. My dad always told me he did his "best thinking under the hood", and I did have a bit of that on this project. I tried to figure out the middle east, oil crisis, and global warming problems, but I think I will need more hood time.Good judgement comes from experience.Experience comes from bad judgement.
Reply:I have welded up similar braces.  Really nice work!Shop rigs -Miller Syncrowave 250 DXMiller 252Home rigs -Esab Caddy c200iHitachi E71 GeneratorMetabo chop saw, grinders, etc Two catsUnhealthy addictions to surfing and demolition derby
Reply:Originally Posted by jtrapper My dad always told me he did his "best thinking under the hood", and I did have a bit of that on this project. I tried to figure out the middle east, oil crisis, and global warming problems, but I think I will need more hood time.
Reply:Originally Posted by jtrapperThe material was 1/4" steel, .035 wire, Airgas tri-mix CO2, argon, and oxygen. Couldn't tell you the amps, it is number 3 on the dial of a millermatic 210. They just went out the door, now I can clean up. My dad always told me he did his "best thinking under the hood", and I did have a bit of that on this project. I tried to figure out the middle east, oil crisis, and global warming problems, but I think I will need more hood time.
GMT+8, 2025-12-25 09:41 , Processed in 0.092501 second(s), 18 queries .
