MIG 2g postion problems
发表于 2021-8-31 23:40:56 | 显示全部楼层 |阅读模式
Running #4 heat, WS 80 on my Hobart Ironman 210 on  .120 wall thickness tube cut in half welded in 2G to some .120 wall tube..You can see  how tall the bead is.  What am I doing wrong?
Reply:I would turn your wire down some, and then adjust the voltage until it runs smooth.  The heat is more than ok, so just put less wire into it with a few more volts to flatten it out.Have we all gone mad?
Reply:high build up like that means your throwing too much wire into work piece. I would try first turning down the wire feed. and if that doesn't work changing our travel speed.
Reply:Slower wire speed.  Will give it a shot this afternoon.Thanks
GMT+8, 2025-12-25 11:41 , Processed in 0.095592 second(s), 18 queries .
