Carbon Arc ??
发表于 2021-8-31 23:40:54 | 显示全部楼层 |阅读模式
Have been told by more than 1 not to Carbon Arc with the SA200 as it could damage the machine, that being said of course many say they have done it. Question is , does the SA 400 have heavy enough windings to do a fair amount of CA without hurting the windings, I am not talking about all day, but for occasional bucket and plow work. My first instinct says it should be fine, anybody have any thoughts?    Have the chance to pick up the 400 in the dollar and amp range, always wanted one but they are a tank. It has 1 cyl that has no compression but runs and welds like it is, could be burned valve , could be just stuck. I know , could be more but the Continental 6 usually hangs tuff."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:You can air arc all day long with a 400, just don't get stupid with it and crank it to "kill" and you will be fine.6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:You would be good to go with a SA-400 running on all cylinders.Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Well , thinking about this one, is all there but as usual , the air cleaner is missing, where do all those air cleaners go? LOL"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by kolotWell , thinking about this one, is all there but as usual , the air cleaner is missing, where do all those air cleaners go? LOL
Reply:Those continental engines are notorious for burning valves and doing stallite seats and rotary's are what needs the be done at overhaul timeHad 2 backhoes with those engines and that cured the problemGood head machinist can do itBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2025-12-25 09:41 , Processed in 0.069791 second(s), 18 queries .
