1959 sa200 cam to crank timing
发表于 2021-8-31 23:40:50 | 显示全部楼层 |阅读模式
I had the engine out of my 1959 sa200 rebuilt and I'm putting it back together. The problem I ran into is that I found the two punch marks on the cam gear but found two punch marks several teeth apart on the crank gear. Which mark on the crank gear do I use to line up with the two on cam gear?
Reply:Crank gear keyway at 12 o'clock, punch mark to the left.Gear Timing.docCam gear is absent but the crank gear is in the proper position.Last edited by duaneb55; 11-18-2012 at 11:47 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Awesome. Thanks. I'll check it out tomorrow.
Reply:Found a shot with the cam gear installed.  Zoom in to see the punch marks.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-25 09:41 , Processed in 0.068954 second(s), 18 queries .
