First welds with the GXT
发表于 2021-8-31 23:40:50 | 显示全部楼层 |阅读模式
All I had around the house was a rusted up peace of channel. INweld 1/8 7018 big nob in the 130 slot little nob on between 8 and 9. In the flat position.Keep in mind I've only had the chance to burn about a hand full of rod in the last 10 years so I am out of practice. The top bead was first the bottom was with the peace already hot cause I was too lazy to go grind on the other end. Attached ImagesRanger 250 GXTSmith Gas Axe
Reply:Now kick the coarse setting up a gear and back off on the "little knob" to about 3-4 and note the difference in bead.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Put the course setting in the 180 slot and worked my way from three to seven on the fine adjustment. I like seven mighty fine pictures tomorrow, I ran out of light tonight.Ranger 250 GXTSmith Gas Axe
GMT+8, 2025-12-25 11:41 , Processed in 0.068610 second(s), 18 queries .
