welding alu with DC pulse TIG/stick welder
发表于 2021-8-31 23:40:44 | 显示全部楼层 |阅读模式
could someone straighten me out on this - I'm looking for a TIG forhobby purposes and was thinking of an AC/DC model to be ableto do alu, but then on another foreign forum I read an old thread where there was mention of welding alu with a DC pulse TIG/stickwelder - is this possible (I forsee doing very little with alu and this wouldsave me quite some money)
Reply:although i prefer to use achf to weld aluminum, i have used dcep to weld it too with tig. i have a lincoln invertec 155 which is capable of only dc welding. with dc though you will need a decent sized tungsten or the tungsten will melt on you. i use a 5/32" tungsten at about 60 amps dcep for aluminum when i cant do it on my big tig at the shop. it works nicely. practice for a bit and you will see just how easy it really is.
Reply:dc aluminum tig also uses helium gas instead of argon.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:looks like you can't get away without spending money(if you need another bottle)  - thanks -I'll look foran AC/DC TIG preferably then
Reply:AC/DC HF is the machine for you. johnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Here is a thread about welding aluminum with DC TIG and Argon.http://weldingweb.com/vbb/showthread.php?t=21510
GMT+8, 2025-12-25 14:53 , Processed in 0.136116 second(s), 18 queries .
