need help hooking up a gas solenoid valve
发表于 2021-8-31 23:40:41 | 显示全部楼层 |阅读模式
I just got a Miller Super S-32P S/N LC142164,that did not come with a Gas solenoid valve.I got one from Millerparts for less,and I have it hooked up,but it will not work.I'm running it off of a Miller Trailblazer S/N 1973728745.
Reply:Nobody? Dwayne? Cruiser? Anybody?
Reply:Got any pics of what you have set up?I have one and can compare it.Plus I am over in the Concord / Farragut area.miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:I'll take some this evening,and send them to you.It has two wires coming out of the back of the square plug,looped back into the plug.I cut the wires,and spliced the wires off the solenoid valve to them.I tried everyway I can think of,and still no success.Thanks.
Reply:I sent you a pm and have some pics and a wiring diagram for you, will be easier using email for me. The two jumper wires you cut and spliced the solenoid valve into is not correct. Put the two jumper wires back together. The valve is connected to the other end of the plug and the contactor. Did the kit you installed come with a purge switch? It plugs into plug number 61 located behind the cover above the drive motor. Just give me a call any time before 10:30, I think we can have it up and running in short order.miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:here is a link to the factory wiring diagram, it is a bit different from the way mine is wired for some reason.Mine came factory wired with the solenoid valve (GS1), do not know if that would make a difference or not.http://www.millerwelds.com/om/o1590g_mil.pdfmiller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:That's for the reply George.No,the kit didn't come with the purge switch.Do I need it for the Solenoid valve to work?As far as hooking the solenoid valve wires up to the contactor.Do you mean the single lead,that is connected to the bus bar?I have that manual you posted,but thanks anyway.I'll give you a shout this afternoon,when I get off work,and back into the Ridge.Thanks alot,Jim
Reply:Originally Posted by RingoThat's for the reply George.No,the kit didn't come with the purge switch.Do I need it for the Solenoid valve to work? No, it is optional, but should have been part of the "kit". If you are wanting to add one you will need a DPDT 15 amp 125 volt momentary switch, a little wire and some crimp on connectors.As far as hooking the solenoid valve wires up to the contactor.Do you mean the single lead,that is connected to the bus bar?one wire from the solenoid to the source lead wire (wire going to the power source welder), this gives the s-32p the power it needs to run itself, if you do not have the contactor then it would go the bus bar.I have that manual you posted,but thanks anyway.I'll give you a shout this afternoon,when I get off work,and back into the Ridge.Thanks alot,Jim
Reply:GeorgeI can't thank you enough.I owe you a beer at least.You're the man!
Reply:Lets get it working first!! ..........and sweet tea for me please!Last edited by G3farms; 11-16-2012 at 01:07 PM.miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:Well I never heard back from ya, did you it getup and running??miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:GeorgeI wound up having to order that connector you gave me the part number for.It was 20 bucks,not too bad I guess.I should be good to go.
GMT+8, 2025-12-25 11:40 , Processed in 0.117923 second(s), 18 queries .
