Leads replacement
发表于 2021-8-31 23:40:40 | 显示全部楼层 |阅读模式
A while back I acquired a Wards/Century AC/DC. I have played with it and decided it is a keeper.I do not know the history of the leads , from the looks of them it must be quite a tale. 1 is about 6 foot and the other about 10 foot with splices.Any how the plugs that attach the lead to the welder are called? I tried every name I can think of on Google and didn't find anything I can identify as replacements. Most are for joining two leads for extension.Can the plastic insulation on my existing plugs be removed and reused also the brass plugs themselves? If not where can I get replacements? Or would making them on my lathe just be simpler?ThanksCal
Reply:You should be able to re-use the plugs and insulators.  Check Welding Depot for the parts.
Reply:There should be a set screw going thru the plastic. I think it is a 1/8'' allen wrench. It's a pin push in connection to the machine. The older Miller Thunderbolt uses the same connector size for their cable to machine. I know TWECO makes them. Measure the diameter of the pin and check welding supplier or TWECO.
Reply:The Century pin plugs are similar to the Miller ones but slightly different in size. Lenco part # UP-10 will fit your machine. Available at your LWS or on line.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Call 866-236-0044. phone number for century division of Lincoln Electric.Ask about the Jack repair kit. It comes with one red and one black jack.easy to install. Can be ordered from any LWS that sells Lincoln welders.
Reply:So charlie  how come no pic of your machine. Dont be shy and welcome to WW.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Here's my story on the pins..."Source for Straight Pin Connectors"....http://weldingweb.com/vbb/showthread.php?t=59737Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Cheap enough:https://weldingsupply.securesites.ne...UNDEF:OR:05270"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by Rick VHere's my story on the pins..."Source for Straight Pin Connectors"....http://weldingweb.com/vbb/showthread.php?t=59737
Reply:Originally Posted by OldendumCheap enough:https://weldingsupply.securesites.ne...UNDEF:OR:05270
GMT+8, 2025-12-25 11:42 , Processed in 0.093577 second(s), 18 queries .
