Adjustable load binder
发表于 2021-8-31 23:40:38 | 显示全部楼层 |阅读模式
I am looking for a load binder that I can weld to a steel plate and use it to hold a door shut. It needs to be adjustable on one end and lock when it "cams" over.I can find these locally, but want one that the j hook screws in and out for adjustment. Attached Images
Reply:You mean like these?http://www.mcmaster.com/#toggle-clamps/=kallw2  There's lots of other variations but these are usually used like you're talking about.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Thanks   Those will work.Sometimes its tough to find something when you don't know what it is called.
GMT+8, 2025-12-25 11:40 , Processed in 0.096106 second(s), 18 queries .
