Gas lens vs gas saver
发表于 2021-8-31 23:40:31 | 显示全部楼层 |阅读模式
What are the difference(s)?  So far, all I can see is the gas savers save on gas and have clear cups.  Anything else?  Regarding turbulence and gas coverage, are they pretty much the same?USINUM - CNC routing workshopPaco's area - blogspot---Lincoln MIGpack180 (GMAW - FCAW)Miller Syncrowave 250
Reply:They are really the same thing.  Both work essentially the same way.Gas lens and a saver both have a mesh screen to diffuse the gas.They do set up slightly different.A gas lens has a screw on cup and a gas saver has a push on Pyrex cup ( tight fit ) with an upper o ring to seal.
GMT+8, 2025-12-25 11:41 , Processed in 0.102214 second(s), 18 queries .
