Linde 225 mig door chart
发表于 2021-8-31 16:58:47 | 显示全部楼层 |阅读模式
I am getting this old welder back on line. But, the paint job is in such bad shape that I can’t read the chart. Trying to reproduce it to have some kind of reference for adjusting. Anyone have a good picture of one of these that can be read easily?BTW I have already measured the wire feed speed at all settings 1-10. Question. Why is the WFS also called “fine adjustment “ on the front of the machine? Also, is there a secret code for the 4 tap heat range working together with the 8 tap heat control? When I measured open circuit voltage on each combination of settings, some of them didn’t make much sense. Example: range-1/ heat control-high gave a higher voltage reading than range-2/ heat control-low.
GMT+8, 2025-12-19 00:41 , Processed in 0.105453 second(s), 18 queries .
