esab/miller spoolgun marriage
发表于 2021-8-31 23:40:29 | 显示全部楼层 |阅读模式
I bid on two esabs on an online auction hoping to get one.  Turns out I won both.I'm now the proud owner of an esab 350mpi and an esab svi300.  both came with linde mig 31 wire feeders.  I was hoping to use these machines to learn dc tig and use a mig spoolgun to learn aluminum for now.  I ended up with two miller 30a spoolguns with w-24 controllers in another auction--same bid/win situation.Anyhoo,  Does anyone have an opinion on which welder I should keep; can one or both be set up to use the miller spoolgun?  The manuals for both the power supplies and spoolguns are not clear about what voltage they use.  I assume the miller controllers- w24 and w115 are used to convert the power supply accessory voltage to the proper one for the spoolgun?Should I email miller or esab about this mixed marriage?Also, the esabs came only with the mig whips on the wire feeder, I have made a new ground clamp and stinger.  Will either power supply need a special tig connector.  My spoolgun win also included about a dozen miller mig guns and several tig setups with thumb switches.  Is a tig a tig or does each manufacturer have a proprietary hookup?thanks for any inputpete
Reply:Yes you can make both of those work.  it may take a bit of creativity to get them to all work nicely together.  I did something similar and had to add a 24vac relay so I could control and trigger the contactor in the machine but other than that getting matching plugs etc and wiring schematics  will have u up and running.  once u have it all together, post over in the electrical forum...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:thanks for giving me hope southpaw--much appreciated
GMT+8, 2025-12-25 15:19 , Processed in 0.110803 second(s), 18 queries .
