Gate hardware question
发表于 2021-8-31 23:40:25 | 显示全部楼层 |阅读模式
I am planning a fence using 2" square tube for the posts and stringers. I want to use 2" for the gate as well. My question is, will a standard deadbolt fit a 2" thick gate? I want to use a standard front door type double cylinder deadbolt so it can be locked from either side.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:i think a standard door is 1 3/4" or 1 /12"  i thinkSIN CITY METAL WORKSvisit my YouTube channel https://www.youtube.com/user/devvon
Reply:My door is 1 3/4" There may be an adjustment on the deadbolts to allow 2" or you may be able to modify the little bar inside and use longer screws?
Reply:Use a lock box.  the the tubing size can be kept the desired size.
Reply:I took Tapwelder's advice and got a lock box. I also decided to make the gate 1.5" to match the lock box and make everything easier.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
GMT+8, 2025-12-25 15:21 , Processed in 0.069398 second(s), 18 queries .
