updated projects
发表于 2021-8-31 23:40:25 | 显示全部楼层 |阅读模式
I have been gone for quite a while. Thought I would post some pics of what I have been doing.This is a self contained all aluminum Crawfish boiler. No need for winches to lift the basket out.When you open the lid, it siys on top of a large cooler.When you tilt the basket all of the crawfish fall into the lid/tray and slide right down into the cooler.Yes I can tack it for you.    I know that won't hold but that is what you asked me to do.  Millermatic 350P XR Aluma-Pro push/pullMillermatic 185/spool gunMiller Dialarc 250 HF Water cooledThermal Dynamics Plasma
Reply:That would be alot of crawfish.  how do you heat it up?Common sense in an uncommon degree is what the world calls wisdom.
Reply:That is the sweet part. It has 3 burners under that are mounted to the stand. The pot just sits in the stand. The nice part is that it only takes about 20 minutes to get to a full boil. When you drop the bugs in, it only takes about 2 minutes to recover. That pot will cook 100 lbs. at a time. I am going to make another piece of aluminum to go into the basket that will raise the bottom to around 8". that way you can use the pot as a steamer for crab and things that needs steamed.Yes I can tack it for you.    I know that won't hold but that is what you asked me to do.  Millermatic 350P XR Aluma-Pro push/pullMillermatic 185/spool gunMiller Dialarc 250 HF Water cooledThermal Dynamics Plasma
Reply:Thats awesome!  Love the basket design. I think you could sell quite a few of them around here.
Reply:Looks good, let's eat.Working on cars and bikes is my hobby, learning to weld the pieces together is my quest.
Reply:Originally Posted by DavidSimLooks good, let's eat.
Reply:i'm wondering if if two pieces of flat bar welded to the lid at a v angle would be useful to act as a funnel so you dont have to worry about aiming it directly into a container. secondly, does it have a drain plug?otherwise, damn thing is brill-yunt, and i will be copying it.
Reply:Originally Posted by rusty ripplei'm wondering if if two pieces of flat bar welded to the lid at a v angle would be useful to act as a funnel so you dont have to worry about aiming it directly into a container. secondly, does it have a drain plug?otherwise, damn thing is brill-yunt, and i will be copying it.
Reply:I want one. How much to build? My contact info... [email protected]. My name is Andy. Thanks
Reply:awesome!  I hope your lovely assistant wears gloves when it's hot!Weld well; grind less.
Reply:Man your making me hungry! Nice work.
Reply:nice cant wit to boil up some bugs 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Where do ya get them aluminum crawfishes?  (sorry...)  Really nice job!(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
GMT+8, 2025-12-25 15:23 , Processed in 0.094637 second(s), 18 queries .
