Table dancing
发表于 2021-8-31 23:40:24 | 显示全部楼层 |阅读模式
Ever get tired of climbing onto your work table with or without a stool?  Check this out: Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Now you've done it!  Gotta add hand rails to the table and wear a full harness and tie off when up on the thing.  And those steps better have a 35sq.in. surface area. Nicely done. :drink up:MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Very neat solution.
Reply:x2 what duane said. also that ladder must have slip resistant feet.  is that table large enough for a waltz or just a moshpit?really nice work.  i especially like the side plates.  cut by hand or cnc?dave
Reply:Nice!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:I like it.!!!  What next; wheel chair ramp?
Reply:Originally Posted by rvpcx2 what duane said. also that ladder must have slip resistant feet.  is that table large enough for a waltz or just a moshpit?really nice work.  i especially like the side plates.  cut by hand or cnc?dave
Reply:Nice fix!I'm lazy, when I need to get up on the table I work on, I just lower it to the floor. Attached Images
Reply:thats the trick just add some yellow caution lights that you would put on the top of your truck and you have a fancy hitech industrial area.  i like how you made the swing guide to make the steps possition out.If you like my stuff you can find me on Facebook.  https://www.facebook.com/theangryanv...ngryanvilforge
Reply:Cool project but WHY do you need to climb on the table?????
Reply:Originally Posted by billsssCool project but WHY do you need to climb on the table?????
Reply:Nice addition, great idea.Gordhttp://gordsgarage.wordpress.com/
Reply:Originally Posted by Broccoli1That's where the girls are
GMT+8, 2025-12-25 15:21 , Processed in 0.070083 second(s), 18 queries .
