Miller diamondback tig torch
发表于 2021-8-31 23:40:19 | 显示全部楼层 |阅读模式
Can anyone put a model number with this tig torch setup? The handle says "miller diamondback" and the head is flexible. The handle has a gas flow control. Attached ImagesMaster Baiter
Reply:master fabricator ?
Reply:http://www.millerwelds.com/om/o1604b_mil.pdfMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Since Weldcraft is part of ITW/Miller I would guess thats who made it.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I'd be guessing but maybe DB17 FV
Reply:Originally Posted by AtticabobI'd be guessing but maybe DB17 FV
Reply:Really?  The blue part looks like a flex head to me....Although I don't remember seeing a flex head torch with a gas valve on the torch...
Reply:Originally Posted by m R g S rReally?  The blue part looks like a flex head to me....Although I don't remember seeing a flex head torch with a gas valve on the torch...
Reply:Actually I just pulled the flex part from what the OP said...
Reply:I just realized it does not flex.Master Baiter
Reply:I know its an old post but I believe it is a Miller Diamond Back TIG torch. Model: DB17V122DPMiller Maxstar 172 TIG (3ph)) converted to Maxstar 152 TIG (1ph), Harris & Victor Oxy/Act, Lincoln WeldPak Pro100, Radioshack 15w Soldering Iron but I want MORE and my wife says
GMT+8, 2025-12-25 15:23 , Processed in 0.077010 second(s), 18 queries .
