查看: 13|回复: 0
Hood customizing
发表于 2021-8-31 23:40:17 | 显示全部楼层 |阅读模式
Hey guys I want a Miller hood with a Jackson head gear.. Anybody ever done it or think it can happen and still work right all day?
Reply:If you are buying a new Miller helmet have you looked at the new headgear?I think they are waaay more comfortable than the Jackson 370If you have an older Miller helmet the new headgear will fit.Jackson 370 h/g in a Miller hood....it would be like nailing Jello to a tree.
Reply:Of course it can be done.ANYTHING can be done if you use your head....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Square peg in a round hole.  Miller uses a square hole and jackson round.   Here is a pic just for u of the miller elite square fitting on next to the hole on my Truesight jackson............ the square is bigger than the hole so a bit of dremel work and u will be all set Attached ImagesTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawSquare peg in a round hole.  Miller uses a square hole and jackson round.   Here is a pic just for u of the miller elite square fitting on next to the hole on my Truesight jackson............ the square is bigger than the hole so a bit of dremel work and u will be all set
Reply:Originally Posted by vwguy3If you are buying a new Miller helmet have you looked at the new headgear?I think they are waaay more comfortable than the Jackson 370If you have an older Miller helmet the new headgear will fit.Jackson 370 h/g in a Miller hood....it would be like nailing Jello to a tree.
GMT+8, 2025-12-25 15:21 , Processed in 0.093868 second(s), 18 queries .
