查看: 13|回复: 0
4 foot gate constuction
发表于 2021-8-31 23:40:14 | 显示全部楼层 |阅读模式
I am building a 4 foot wide x 6 foot tall gate tomorrow. I am using 14 guage 1.75" square tubing. I have built lots of wood gates, but this will be my first steel one. The steel will just be for the frame, the gate will be clad with corrugated tin. When I build wooden gates, I always run a diagonal from the bottom hinge side to the top latch side to prevent sagging. Is this the way to do it on a steel gate?I also though about running angled pieces on the inside of all four corners. What is the best way to make a strong gate frame that won't sag?Thanks, BigBMiller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:No need to do that with a span of 4 feet. Not with steel anyway in my opinion.
Reply:Here is a personal gate I did a week or so ago. If you put pickets on it like this it should be plenty rigid and not sag at all. Attached Images
Reply:Originally Posted by bigbI am building a 4 foot wide x 6 foot tall gate tomorrow. I am using 14 guage 1.75" square tubing. I have built lots of wood gates, but this will be my first steel one. The steel will just be for the frame, the gate will be clad with corrugated tin. When I build wooden gates, I always run a diagonal from the bottom hinge side to the top latch side to prevent sagging. Is this the way to do it on a steel gate?I also though about running angled pieces on the inside of all four corners. What is the best way to make a strong gate frame that won't sag?Thanks, BigB
Reply:Originally Posted by BlazinHere is a personal gate I did a week or so ago. If you put pickets on it like this it should be plenty rigid and not sag at all.
Reply:Photo of two simple gatesJust some ideas.AWS certified welding inspectorAWS certified welder
Reply:Originally Posted by Donald BranscomBut it looks like a jail. Sorry.I see houses in the background like a residential area.
Reply:Originally Posted by BlazinSorry?  Its ok everyone understands what opinions are like! Here's one for ya! Looked up some of your "metal scuplture" and I've seen art work from inmates that looks a hell of alot better than that crap! These gates were built as a requirement for FD entry and not for aesthetics. They had to be built relatively inexpensively and fairly quickly on site for a place of worship. All the labor which is now into the 24th straight weekend was volunteered and not paid. I was just offering an example for the guy trying to get ideas for a small gate. For someone 61 years old you've got an extremely inflated sense of yourself. Post some pictures of your own work besides a chopped up tractor/motorcycle seat and some scrap iron thrown together that you call "art" or shut the hell up!
Reply:Originally Posted by umahunterdam you gonna hang around here ya better get a lil thicker skin
GMT+8, 2025-12-25 15:19 , Processed in 0.078560 second(s), 18 queries .
