ESAB Rebel Tig Torch upgrade
发表于 2021-8-31 16:58:47 | 显示全部楼层 |阅读模式
Hello everyone, i have the Rebel 215ic, I’m a novice welder but I’m interested in learning Tig welding, even being a novice i can tell the oem torch is not very nice to work with, Can I purchase a Basic CK torch with gas valve an modified it myself to fit my machine or do i have to pay more an purchase a direct fit kit.? Thanks.
Reply:see if the machine connector can be removed. You may be able to use them on the CK torch. See if one of your local welding supply stores sell ESAB  and CK torches and will know what is needed to adapt. Try to gently pull black plug cover up the weld cable on the torch.
Reply:I wonder if you have any ideas for modifications?
Reply:https://usaweld.com/collections/esab...the_torch_headMike
Reply:A great device with efficient air cooling!
GMT+8, 2025-12-19 00:41 , Processed in 0.103529 second(s), 18 queries .
