skeg
发表于 2021-8-31 23:40:13 | 显示全部楼层 |阅读模式
welded a skeg today Attached Images
Reply:Looks good.And now I know what a skeg is.
Reply:I always though a skeg was a Booger.....
Reply:Would you mind telling what settings and filler you usedThanks
Reply:Originally Posted by mtngunLooks good.And now I know what a skeg is.
Reply:setting are balance 75% ac frequ. 125Hz amp 190but i have a good foot pedal (not a $50.00 one)i did it a little at a time so not to melt the seals4 hours. forgot 4043 rod and the guy brouht it in that way. easy moneyLast edited by ed mac; 03-13-2011 at 08:46 PM.
Reply:Looks good to go.A buddy of mine saw me doing one, it was a much smaller broken piece than the one you did. I added some flat stock and shaped with grinder. Buddy tells me a new weld in skeg can be purchased for some models.PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:Originally Posted by Stick-manThis is a skeg for summer use. There are also skegs for winter use. They are found on the bottom of snowmobile skis. Those are the only two "skegs" that I can think of. Just a little FYI.Looks good ed mac. How did it get broke. The majority of the ones I hear about, at the bait shop, get ripped off and are not found. That is obviously not a new one you've welded on.
Reply:I've done a few of these myself. When they are real bad I buy a replacement skeg and weld on. Attached ImagesLast edited by Showdog75; 03-13-2011 at 09:05 PM.
Reply:you can buy them new from the factorywhen a lower unit dont pass. they cut the skegoff and sell them i get them from the boat house in melbourne fl
Reply:Those are both real nice repairs you guys have done. Good work!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:when i used to do these at work, we refused to do them unless they were, or could be dismantled. we would clean them within 2 inches of the weld, and heat to 450 before welding. we also repaired outboard jet unit feet the same way.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Very nice looking welds.Did you drain the lube and remove the prop shaft, bearings and seals before welding?"The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
GMT+8, 2025-12-25 16:57 , Processed in 0.114506 second(s), 18 queries .
