1 1/2" tube notcher
发表于 2021-8-31 23:40:13 | 显示全部楼层 |阅读模式
Just built this notcher to do some tubing projects.  Looks kinda hillbilly but I wanted to make sure it worked before putting too much time and $ into it.  It cuts a perfect notch.  I need to fine tune the tracking and put a higher hp motor on it (had an old 3/4 hp laying around).  Youtube:VID 00009 20110313 1309 Cletis
Reply:Nice work, cletis.Here it is.[ame]http://www.youtube.com/watch?v=tAoGU4gDY8E[/ame]
Reply:Nothing hillbilly about something that works that nicely.  Good job!Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Very Cool Indeed...!Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:very cool. Is there any way to adjust up and down to adjust for different size tubing?
Reply:Nice...how long will a belt last?Millermatic 252Syncrowave 200Kalamazoo 9AW
Reply:D@MN FINE WORK !!!Looks great....worx as intended, and can be multifunction.  You just got an A+.JD
Reply:The table is set for 1 1/2 tube but bolts on so would be easy to change.  Now that I know it will work I may experiment a little and end up making an adjustable table or better yet the real models have vises which move x and y.  That would be cool.The company that made my contact wheel said it would be difficult to make a smaller contact wheel to fit because you only have so much room for the bearings, roller and the compound they put on the roller.  You could however go larger but for what I am doing I don't have a need to yet.I think the belt will last a long time.  I couldn't even tell I had done any grinding on it.
Reply:I should mention not to look at the welding very close.  It's really bad.  The welder is a mth old and I've had issues with it since it was new.  They are going to replace it for me so I have an excuse for how sorry they are.
Reply:Really neat invention! If you hadn't already thought about making a guide, you could easily make one that hangs off the end of the table with an adjusable fence to get the angles just right. It would be a seperate peice that you could slide left-right similiar to what your doing in the video. I made a quick sketchup of what I'm descibing in "red". Attached Images
Reply:If that's Hillbilly, the suits better be watch out!!!! Nice job! Nice idea on the miter gauge too Mark! I just don't have the aptitude or time to learn a drawing program. Nice for designing stuff like this.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:That's a very good idea.  I could adapt that miter gauge to what I have very easily.Cletis
GMT+8, 2025-12-25 15:14 , Processed in 0.093707 second(s), 18 queries .
