Walkin the cup - Vertical up
发表于 2021-8-31 23:40:09 | 显示全部楼层 |阅读模式
Well i did a little practice tonight, really trying to learn how to walk the cup. So here it is...
Reply:looks like u r getting it
Reply:The only cup walking I've done is on open root pipe welds. Otherwise I usually just free hand it. Your on the right track. Looks decent.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Not to bad. Try to maintain equal distance in the cup movement this is easier done on open roots. Work on keeping the wrist staying straight and don't rotate it at the end of the weld. When you start the weld work on incorporating the last puddle with your new weld bead.Keep on going and you'll get smoother.Weldor/ Certified Inspector
GMT+8, 2025-12-25 13:20 , Processed in 0.076116 second(s), 18 queries .
