Passport Fan comes on
发表于 2021-8-31 23:40:07 | 显示全部楼层 |阅读模式
When the Passport fan comes on, should I quit welding? Then wait for it to quit before I start again. I Just finished welding my gates. Got good at fitting them together. Finished a 10' 1 7/8" 4 rail in 1 hour.Will be installing 2 - 10 footers this weekend.Vern
Reply:You need to refer to the duty cycle rating for you machine. That is the best way to determine if you are over working the machine. Most if not all are based on 10 minute time period. So a 50% duty cycle means that you can weld for 5 out of 10 minutes. The fan coming on just means that the machine has reached the preset temp to trip the internal thermostat. No need to stop welding unless you are exceeding the duty cycle.SA200,Ranger8,Trailblazer251NT,MM250,Dayton225AC,T  D-XL75,SpoolMate3545SGA100C,HF-15-1  RFCS-14 When I stick it, it stays stuck!
Reply:What does the owners manual have to say? I would prefer that the cooling fan run continuously to keep the power supply as cool as possible.
Reply:I really can't watch a clock while welding. Do I use an egg timer?I bought a tile meter for 4x4 driving. I've set it for tilt and climb for my truck. I don't have to watch it. there's a slow, fast or steady beep when getting close to max setting. I know my front or side tilt from what I hear. From the looks of this chart I'm no where near the duty cycle. Welding 14 gage. Seems like the fan comes on after 2 minutes.Vern
Reply:The Passport is Fan On Demand and also has Thermal Overload protection.You do not have to stop welding when the Fan comes on but wait to turn OFF the machine until the Fan stops.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1The Passport is Fan On Demand and also has Thermal Overload protection.You do not have to stop welding when the Fan comes on but wait to turn OFF the machine until the Fan stops.
Reply:Yep, what Ed and Transit said.  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Thank you!It' imposable to hear the fan running when it's on a gas generator. When my wife shutdown the generator last night, I had that thought. WAS THE FAN RUNNING?Vern
GMT+8, 2025-12-25 13:27 , Processed in 0.166257 second(s), 18 queries .
