Porosity of Cast Iron Head
发表于 2021-8-31 23:40:05 | 显示全部楼层 |阅读模式
I'm new to the forum and don't know a whole lot about welding. I generally leave it up to the pros. My question is about adding material to a cast iron head (69' B20 Volvo) exhaust port to improve flow. The shop that is doing this just sent in a group of 4 heads to get Furnace heated, welded, and cooled to add material (cast iron). Shop says all heads came back bad - leaking and porosity problems. Welder says you can't pressure test with air to verify the work. All cast iron is porous and will leak air. The shop then pressure tests with water and now says no leaks on the four heads. The shop has been up front with me in the past, I don't think shop owner has a lot of experiance with this type of welding process, says he got an experiance welder with good rep. Is this hogwash or is it believable? Does Cast Iron leak air? Thanks Rich B
Reply:Originally Posted by rich bDoes Cast Iron leak air? Thanks Rich B
Reply:^^^^^^^ what zap said you got a welder at that shop that does not know what he is talking about / DoingMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Do a search of member castweld to see his work and I think you'll find the answer to your question.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-25 13:28 , Processed in 0.106670 second(s), 18 queries .
