Mig and stick on the same workplace at the same time
发表于 2021-8-31 23:40:02 | 显示全部楼层 |阅读模式
Is possibale to run mig and stick to the same workplace at the same time ? Given than one is dcen and other dcep ?
Reply:In short that answer is YesMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Well, yes, as long as we're talking about 2 different machines, not one multi-process machine like an XMT.However, hard-wire MIG is DCEP, and so is most stick welding. Unless you are using self-shielded flux-core, it shouldn't be an issue.JohnA few weldersA lot of hammersA whole lot of C-clamps
GMT+8, 2025-12-25 13:27 , Processed in 0.110242 second(s), 18 queries .
