Leads and lugs
发表于 2021-8-31 23:40:02 | 显示全部楼层 |阅读模式
I see that lugs are mostly crimped and not soldered. Is it because the joints get that hot or another reason? 400 F seems a bit warm under normal working conditions. I would think solder would give a better connection.
Reply:I don't know the 'real answer' but...a) The joints don't get hot enough to melt solder ~400Fb) Yes solder would give a better connectionc) Solder would also prevent the oxidation & corrosion of the individual wire standsIt would seem to me that a crimped joint (mechanical), followed by soldering would be best.On the other hand, many 'connectors' are constructed to be tightened with Allen screws.  However, unlike lugs, those connector joints are designed to be taken apart from time to time.IMORick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:I used to solder every one. I have, one by one, cut the solder joints off and now use the ball screw joints, or the crimped lugs. The reason is that the soldered joints have all failed over time and created a high resistance joint, which then gets hotter, and hotter, the worse it gets. I don't know why they fail like that, but they all have. Stick with the crimps and the ball screws.
Reply:This topic has been discussed many times here and in considerable depth in this particualr thread http://weldingweb.com/vbb/showthread.php...=solder&page=4 with some great tests performed by member David R on page 4 starting at post #85 a couple years ago.  A good read.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:most people use these and eliminate hammer on lugs  Lenco 08030  it bolts to your machine post and give you a 40mm female that will accept a standard male cable connector
Reply:WOW! Watta read.Thanks
GMT+8, 2025-12-25 13:28 , Processed in 0.074826 second(s), 18 queries .
