Broken spoolgun power cable fix
发表于 2021-8-31 23:40:01 | 显示全部楼层 |阅读模式
Any ideas? The 2 awg wire on my new to me magnum sg spool gun failed. Guessing it's from repetitive bending in the same spot... Everything else checks out ok as far as I can tell.  Thinking I would like to put a bolt type connector and shrink wrap Or something along those lines... Any thoughts?  Thanks
GMT+8, 2025-12-25 13:20 , Processed in 0.189924 second(s), 18 queries .
