Blanchard grinding
发表于 2021-8-31 23:39:59 | 显示全部楼层 |阅读模式
For those of you who have had a table ground out what does that usually cost?i have a 3x4 1/2 table that i would like to get ground but i have a couple of problems.1. there doesnt seem to be anybody around atlanta that does such a large format. which leads me to think it is $$$$$$$2. I havent got a clue what it would cost.but what search terms do you guys use i seem to be running into stump ginders mostly =/
Reply:http://www.atlasmachine.com/shopcapa...shop/index.phphttp://local.juneauempire.com/osage+...inding.zq.html"large surface area grinding shops (your area)""Any day above ground is a good day"http://www.farmersamm.com/
Reply:For your reference,  my 5x8 cast iron table was $900 for surface grinding. That involved grinding the top, flipping it over and grinding the underside & then flipping it over again and going over the top one last time.
Reply:I paid $200 to have a 48x70x0.625" plate done.  It took a couple calls to find someone that would do that size...it takes a large machine.  I feel like I got a pretty good deal.Edit: Also, just call someone that does blanchard grinding.  Usually, if it's too big for them to do, they will probably tell you who will do it.  They aren't really losing business for something they don't have the capacity to do.....http://www.cgmetal.com/http://www.centerlessgrind.com/blanchard.htmLast edited by kazlx; 12-04-2012 at 01:53 PM.
Reply:Only place with in 250 miles. wanted $400..guess im not getting it ground.
GMT+8, 2025-12-25 13:28 , Processed in 0.086393 second(s), 18 queries .
