welding pup piece at pressure containment pipes
发表于 2021-8-31 23:39:59 | 显示全部楼层 |阅读模式
hi,i looking  for advise about welding pup piece of 60mm length in between flange and 6" pipes. when completion of the spool it will be pressure containment function during operation . according  to client specification 100mm weld space needed. i have check the API 5L standard is minimum 50mm. how about ASME code? can anyone  advise me 60mm is good for the work with refer in what document. i will be appreciate. all pipes material  is super duplex. Sent from my GT-N7000 using Tapatalk 2
GMT+8, 2025-12-25 14:53 , Processed in 0.177008 second(s), 18 queries .
