Cart for Weldanpower 225
发表于 2021-8-31 23:39:52 | 显示全部楼层 |阅读模式
Hey;Just finished this one using 3" channel , 2" angle iron and rectangular tube. Made cable rack and a tool box rack on the opposite side.Put a rectanglular receiver and hitch so that I can hook it up to pull with the tractor.  Should hold together for a while. Attached Images
Reply:Nother Attached Images
Reply:That looks like it'll take a hell of a of thrashing and not even squeak!!!! Nice job!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:good thing you put that hitch on it, i dont think you want to use that handle too much..very nice..
Reply:Did your 225 have it's original roll around frame under it, and that has been improved,  or was that seperated somewhere along the way?   Either way it came out real keen.  I like the cable rack and tool box holder?  Pull it with your aTV maybe?  enjoy, BretLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Papaloin...Hey dere , she come in rough form with only the factory channel steel, I took it from dere.I ordered them wheels solid, so that I don't have to fool with air leaks. Rated at 360 pounds load ea. if memory serves. Figured anything worth doing , worth doing right. I got a lot of good help from friend and through this fourm. She was rough with a busted through bolt and waay busted up fan. I rate Stumpfs pretty high! You just gotta eat your breakfast before welding! LOL
Reply:Hey dere;For those wanting to know, here is the original Babe when i got here early in the year. Busted fan , through bolt, and all the rest. Did bodywork on her with my anvil and body hammer, Rustoleum all the rest. Sunrise red is what I ended up with, looked nice and birght to me.Welded the cart using her AC power and 150 DC -  with 1/8" 6013. Worked good for me. Got exceptional penetration on the 1" Rounds I used to fabricate the cable holds with. Special thanks to Duane B, smart fella.   Attached Images
Reply:how do u like the power?
Reply:Hey ;To me it has a load of power and that Briggs is as dependable as it gets. Puts out good aux power too, which is handy as heck Originally Posted by bp626indamixhow do u like the power?
Reply:Originally Posted by HorvikHey;Just finished this one using 3" channel , 2" angle iron and rectangular tube. Made cable rack and a tool box rack on the opposite side.Put a rectanglular receiver and hitch so that I can hook it up to pull with the tractor.  Should hold together for a while.
Reply:Yep, just finished a tool box for it, out of 3/4" construction grade plywood. Oil primer and Rustoleum finished the job. Here's the picture. All the best Originally Posted by jwormanWow!  I had a Weldanpower 125, and I messed around with the cart it came with.  Yours is far far nicer.  A really fine job!
GMT+8, 2025-12-25 15:14 , Processed in 0.110447 second(s), 18 queries .
