查看: 13|回复: 0
generator for mig
发表于 2021-8-31 23:39:43 | 显示全部楼层 |阅读模式
I need to weld some round hay feeders back in the field. I have a Lincoln power mig 180 and a Clarke 130en. Would either or neither work ok on a 5500/8500 watt peak generator.Or should I load the feeders up and take them to the shop. (not much fun).Thanks
Reply:5500 continuous watts;  At 120 volts, 5500/120 = 45.3 ampsAt 240 volts, 5500/240 = 22.9 amps8500 peak watts;At 120 volts, 8500/120 = 70.8 ampsAt 240 volts, 8500/240 = 35.4 amps.These are the maximum currents that the generator can deliver.If the welders consume less current than can be delivered continuously [5500 watts] you’re ok.The 8500 w will handle the peak surge when you start the arc.
Reply:Seems like it would be a good idea to try the machine out with the generator before hauling it out to the field.Some of them little lashups work, sometimes.
Reply:Thanks for the replies. Is there any chance of ruining either the generator or the welder? Or will it just not deliver enough current to give a good weld?I don't want to hurt the generator before winter is over. Feb 2009 it saved our necks, during a ice storm. no electric for a week.
Reply:Originally Posted by hd5Thanks for the replies. Is there any chance of ruining either the generator or the welder? Or will it just not deliver enough current to give a good weld?I don't want to hurt the generator before winter is over. Feb 2009 it saved our necks, during a ice storm. no electric for a week.
Reply:I can run my HH 187 off of my Kubota Diesel generator 6500/6000 without any problem. I doubt you'll be running the larger welder all out to weld hay feeders depending on what they are...... mine are heavy duty rings but still fairly thin material after a few years of rusting in the mud all winter (makes it a challenge to do any sort of repairs on them).HH 187Miller Bluestar1EAHP AlphaTig 200X
GMT+8, 2025-12-25 16:57 , Processed in 0.234999 second(s), 18 queries .
