Another day
发表于 2021-8-31 23:39:40 | 显示全部楼层 |阅读模式
Here's to jobs that I have been part of..One is of some 8" pipe work and the other is a door that gets some brick. It's constructed of 1/4" plate and flat bar for reinforcement. The pipe was welded with .045 mig on 98/2 and with the voltage turned down a bit, the flange was welded on. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:and more Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:I wouldn't want to be the guy in the last picture, I don't care how many chains there are, sh*t happens.
Reply:Yeah... a 10 ton chain failing on a 1500 lb weight would be a bad dayCommon sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-25 18:51 , Processed in 0.121709 second(s), 18 queries .
