Another gate help thread???
发表于 2021-8-31 23:39:40 | 显示全部楼层 |阅读模式
i was asked to build a single swing gate for a  Mexican brick wall that the old gate ripped out of.  i usually use a  2x2 095 post sunk 24" and 065 frame.  then cover in redwood pickets the gate will be 5ft usually anything over 4 i put a wheel on but there is no way to do that here.  because of a shed the gate can only swing out into the alley which drops like 18 inches once opened  i planed on some tabs on the post bolted to the brick do you think this will be enough to prevent sag or should i bump it up ?????350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
GMT+8, 2025-12-25 15:12 , Processed in 0.071118 second(s), 18 queries .
