Hyd. Tubing, weld on fiting
发表于 2021-8-31 23:39:31 | 显示全部楼层 |阅读模式
I need to weld the fitting on 5/8 steel tubing, it is .o65 thick walls,  what is the best wayto make the weld??  and do i need to flux, like copper tubing?? I have a harris tourch setup,  or do i need tig/ mig ?? thanks, sam
Reply:if you have to ask normally you should not be doing it That hose is a pressure vessel what is the fitting made out of ?little more info if you ship it to me i will do it for you for freeMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Hi Wookie, For now i have rebent the old line and re-connected the line, i have the tubing cut to make another one, i think that i will buy new ends to weld on. I'am sure any good welder could do the job,I'am just started to learn welding, so far cutting out 3/4 bolt broken off, got any good advice.sam.
GMT+8, 2025-12-25 15:12 , Processed in 0.139552 second(s), 18 queries .
