outdoor worktable
发表于 2021-8-31 23:39:19 | 显示全部楼层 |阅读模式
i like to call this my "smithing table". at first it was just the 3/8 angle iron part with a 1/4in plate on top. i added the vise,rail,and plate on the end.next step is to put some sort of slag tub underneath.its really handy,and heavy!!the bars are what were used to bolt rail together.there dated 1944,the rail1924.did i mention that i didnt pay a dime for any of the material!!. its all been done with my ranger 225,6011, 7014,and 7018.the legs on the end will be cemented in the ground like the rest of the table when the ground softens up. Attached Imageslincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:if u go to you tube type smithng table and you can see some of it being built.check it out!!lincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:IF YOU GO TO YOU YUBE TYPE SOME THING TABLE AND YOU CAN SEE SOME OF IT BEING BUILT.CHECK IT OUT __________________lincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylene:confusedpuroxcw202victor fc100harris model 85harrismodel 16oxweld w24roxweld w17burewalakhiljiburewalakhilji
Reply:man how far upstate are you? we lost our snow here in poughkeepsie last week.your work area reminds me of mine...
Reply:Originally Posted by weldbeadman how far upstate are you? we lost our snow here in poughkeepsie last week.your work area reminds me of mine...
Reply:this slag tub was thrown together sunday in the 20 degree weather!!.its a bit overbuilt but the material was free and its been laying around for a while.im going to make a plate in the front that can slide to clean it out. i made brakets but i dont have anymore 5/16{or1/4in}plate left!ill keep u posted.as the ideas roll in the table will be expanded accordingly. Attached Imageslincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:im in tupper lakelincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:Originally Posted by ranger225im in tupper lake
Reply:i built it to last and im about done with winter!!.lincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:Nice. We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:cool i havent seen snow in 6 years
Reply:Originally Posted by jreynoldsweldingYea, looking at the pictures I thought it was yours
GMT+8, 2025-12-25 16:58 , Processed in 0.144019 second(s), 19 queries .
