Stainless Ring Field Job
发表于 2021-8-31 23:39:18 | 显示全部楼层 |阅读模式
Last week I got sent out on a field job to weld an extension onto the stainless access hole of a big concrete tank that is under construction.(Click images for larger view.)Here's the hole with the 1/4" thick SS ring next to it:For the weld prep, the specs called for a 1/8" deep v-groove on the inside of the tube/ring:Root pass was done autogenously (no filler):Hot/fill pass:Cap pass:Specs also called for the weld to be ground flush (I also smoothed it with a flap-disc):Here's my work area right after I finished the welding and grinding:I had to keep everything right up against the wall of the tank, out of the way, because the concrete guys kept driving their man-lift things around the tank prepping the outside for the next coat of concrete.Visit Tensaiteki.com
Reply:Nice job, damn concrete guys lol
Reply:Originally Posted by 7A749Cool How many hours did you have in it from start to finish?
Reply:Looking at what quarter can be seen it looks like that could be a pretty good sized tank if there's any height. Sweet work."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
GMT+8, 2025-12-25 16:58 , Processed in 0.135408 second(s), 18 queries .
