Is H Beam made with different types of steel?
发表于 2021-8-31 23:39:17 | 显示全部楼层 |阅读模式
Is H Beam available in different types of steel?Specifically, if so, which type of H Beam is the stiffest (which type of steel)?Something 6-8 inches high.Regards to all.Working on cars and bikes is my hobby, learning to weld the pieces together is my quest.
Reply:Guess you can't be bothered to do your own search?http://www.weldprocedures.com/beamchart.htmlBlackbird
Reply:Originally Posted by DavidSimIs H Beam available in different types of steel?Specifically, if so, which type of H Beam is the stiffest (which type of steel)?Something 6-8 inches high.Regards to all.
GMT+8, 2025-12-25 16:58 , Processed in 0.464915 second(s), 18 queries .
