查看: 13|回复: 0
Cast Iron Chain and Anchor Mfg.
发表于 2021-8-31 23:39:13 | 显示全部楼层 |阅读模式
Check this out.  How would you like to have worked on these jobs under these conditions?  So much for the "good old days""The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Wow.   They must have had a lot of injuries.  There is another vid like that one too.[ame="http://www.youtube.com/watch?v=nLIbObCltfQ"]http://www.youtube.com/watch?v=nLIbObCltfQ[/ame]Victor Oxy weld/cut Setup Meco Midget Torch outfitEverlast 2016 250EX & Power Cool W300Lincoln Power mig 210MP  w/amptrol and Spool GunEverlast Powerarc 200 Hypertherm Powermax 45Bandsaw, Lathe, grinders, press, Bridgeport, etc.
Reply:Amazing to see each person working in Perfect timing with each other. Thats when men were real men and earned their pay , eventho it most likely wasnt much.
Reply:Originally Posted by Swamp rat Thats when men were real men and earned their pay , eventho it most likely wasnt much.
Reply:That right there is "MANS" work. And if it don't make a man out of you, it will kill you.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by HousedadWow.   They must have had a lot of injuries.  There is another vid like that one too.
Reply:Did you see the guy working there in a shirt and Tie
GMT+8, 2025-12-25 15:19 , Processed in 0.103191 second(s), 18 queries .
