Air Dryer
发表于 2021-8-31 23:39:04 | 显示全部楼层 |阅读模式
Now i will start out by saying - what i know about a plasma cutter you could put on the head of a pin and still have room - now i read a lot of post about needing a air dryer with one and some type of filtration system - now they have one at work - have never used ithas no dryer or filter in line - am looking at getting one - small 40 amp model - my question will the following one work - thanks for your help Attached ImagesThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:That dryer will work fine as long as the Plasma system air flow is rated below the air flow rating on the dryer. It looks like it can handle 7 cfm.....so should be ok for most 40 amp plasmas.Jim Colt  Hypertherm
Reply:thank youThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
GMT+8, 2025-12-25 17:19 , Processed in 0.133125 second(s), 18 queries .
