Hi guys, I've got a little Lincoln Mig welder. Gas started leaking out of the pressure relief of the regulator today. My Regulator is the Victor 2570 like this onehttp://www.scottgrossstore.com/servl...-Single/DetailA new one is quite expensive and I only weld a couple of times a year. Can anyone recommend a new one that costs significantly less? Should I look for a rebuild kit for this one? Is Victor a superior product. This thing is probably 20 yrs old.
Reply:buy a radnor flow meter from Air Gas for about 80 bucks.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Thanks jbmprodsDo you have any idea what makes my old regulator so expensive? Maybe it's built better and lasts alot longer? You sound confident the Radnor will do me just fine
Reply:i am not familiar with that particular reg so i can't comment on why it's so costly, but it is a victor. i have 5 radnor meters and several of them i have used for years and never had a problem with them. you can always pay more but that doesn't mean they will do more or last longer. check with air gas about having yours rebuilt. it might not cost the 80 bucks that the radnor meter does. i have had several regs rebuilt but i always keep extra sets for when one goes down. after all they only break when you need them.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Is the relief valve leaking around the threads? or somewhere other than there? If it is at the threads you can remove the valve and wrap the threads with T-tape and reinstall the valve tightly. Yes to your other question Victor is a superior product to most,but only using it a couple times a year, you could get buy with a cheaper flow meter if yours couldn't be fixed.
Reply:The Victor 2570 is a regulator flowmeter with a valve seat and diaphragm deisign. The inexpensive one that sell for $80.00 is psiton type regulators. The valve seat diaphragm style is more expensive because it has more parts and a more detailed machined body that a psiton style. Both the valve/diaphragm and psiton style Victor regulators use a fixed pressure and an adjustable orifice to control flow rates. New, both units will work the great, however, over time the plastic seat in the psiton sytle will begin to flatten, changing the pressure of the regulator and make the flowmeter less accurate.We do service for Scott Gross and they are a great company. The rebuild cost for your 2570 through them is probably about $60.00 to $65.00. Hope this info helps.JimOAdoctorwww.regulatortorchrepair.com
Reply:Originally Posted by OAdoctorThe Victor 2570 is a regulator flowmeter with a valve seat and diaphragm deisign. The inexpensive one that sell for $80.00 is psiton type regulators. The valve seat diaphragm style is more expensive because it has more parts and a more detailed machined body that a psiton style. Both the valve/diaphragm and psiton style Victor regulators use a fixed pressure and an adjustable orifice to control flow rates. New, both units will work the great, however, over time the plastic seat in the psiton sytle will begin to flatten, changing the pressure of the regulator and make the flowmeter less accurate.We do service for Scott Gross and they are a great company. The rebuild cost for your 2570 through them is probably about $60.00 to $65.00. Hope this info helps.Jim
Reply:I have dealt with oadoctor, and highly recommend him, good guy to do business with.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools |
