304 tubing
发表于 2021-8-31 23:38:56 | 显示全部楼层 |阅读模式
Where is a good place to get 304 round tube seamless?  Online is ok but if there is a local source in the tidewater area of Virginia I would rather go that route for quick pickup and keeping money local.  Ideally I'm looking for 0.75 ID to use in a low pressure liquid cooling set up for a computer system using non conductive liquid.  0.50 304 cress double barb npt's with an as yet determined gasket will be used at the connection points.Welding Supervisor Department of Corrections.
Reply:Do you have BMG or Steel Services in your neck of the woods?  I use them, and Dillon Supply, for steel purchases.  They are all either local or deliver locally.  (I'm in Harrisonburg)
Reply:Ill have to check, so far I haven't found any place with items in stock.Welding Supervisor Department of Corrections.
GMT+8, 2025-12-25 21:00 , Processed in 0.106897 second(s), 18 queries .
