cyl head repairs
发表于 2021-8-31 23:38:46 | 显示全部楼层 |阅读模式
Easy  repairs, funny story.This came from a NAPA machine shop a couple parishes (counties) away. The Sheriff Dept uses inmate (free) labor to repair their cars. The heads were on a Chrysler that had an exhaust leak. Inmate found broken exhaust manifold stud, removed manifold and tried to drill it. As you can see in pics he drilled half in broken stud and half in head. Can not tell in pic but he drilled into water jacket also. Supervisor decided that best deal would be to take both heads off, to repair goof and check both for cracks and resurface. Pics of second head shows valve cover rail cracked in two places. Inmate thought he had all head bolts removed but.... He used pry bar to unstick head and broke one area, I guess that did not give him a clue about the remaining bolt, so for good measure he broke the second area. Pre and post heat 350*, tig with 4043, machine to fitPeter Attached ImagesEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:second head Attached ImagesEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:Gotta love that "free" labor. Great work as always Peter.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Gotta love that "free" labor. Great work as always Peter.
Reply:I have watched several of you rposts, great work.  Question.  I assume on the second head for prep work you die ground to groove around the crack.  CorrectGeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
Reply:well it would be a wild guess but im guessing some of em aren't in there cause there brilliant 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:OR, the inmate had an inkling that the head would have to be repaired, most likely within state, and decided to "goof" in order to help create some work and in turn "stimulate" the economy . . . . . . . Naw!!! Last edited by Brink, M.E.; 04-14-2011 at 11:39 PM.Reason: messed up the smiliesMikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:Originally Posted by geezerI have watched several of you rposts, great work.  Question.  I assume on the second head for prep work you die ground to groove around the crack.  Correct
Reply:Originally Posted by castweldThanksDid Ford get his Ford running?Peter
Reply:Good old 4.7 liter , they are getting hard to find good cores . They seem to break where the chain guide pivot bolt screws in on the left head (be very careful ). Or they warp , since they allow no warpage it doesn't take much.
Reply:Sure the inmate didnt do it just for spite? I'll bet thats one motorpool where all the employees are disgruntled. LOL I am sure the brightest are not turning wrenches for the county for free.Nice repairs. Had a nice set of 041 vw heads that had a crack between the intake andexhaust on the number three cyl. Wish I coulda welded that, or known someone who could. Those were nice factory race heads. Don't think you can get anymore.........Mike
Reply:Originally Posted by allfluxedupSure the inmate didnt do it just for spite? I'll bet thats one motorpool where all the employees are disgruntled. LOL I am sure the brightest are not turning wrenches for the county for free.Nice repairs. Had a nice set of 041 vw heads that had a crack between the intake andexhaust on the number three cyl. Wish I coulda welded that, or known someone who could. Those were nice factory race heads. Don't think you can get anymore.........Mike
GMT+8, 2025-12-25 21:00 , Processed in 0.076717 second(s), 18 queries .
