Monster Truck Stuff
发表于 2021-8-31 23:38:46 | 显示全部楼层 |阅读模式
Another repair, The never ending story of of destruction, Attached ImagesI hate rude behavior in a man.......Won't tolerate it!                   Woodrow F. Call
Reply:Wow, was that flange cast? If so , is it gonna hold up ? Can another flange be put along side or maybe two sandwiching the broken flange? Would that even help? Looks like an expensive break ,but I imagine everything for that would cost an arm and a leg.........Mike
Reply:By the way, I am not being criticle here, I genuinely dont know and my curiosity is peaked by this......
Reply:critical sp? , nope cannot spell and plenty of twyposMLM
Reply:TIG with Ni filler?
Reply:id have liked to see the fotos betwwen 1 and 2.. the break sure looks cast but if you look in foto 2 that whole axle  is welded together including connecting the flange to the box...bead  looks like silibronze but that would be a weak choice....
Reply:Dual Shield? Looks Similiar to the Excel Arc 71 (Hobart)Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
Reply:The flange is cast steel, It is MIG'ed to the end of the housing which is mild. I used er70-2 then post heated to anneal the weld. It is the second one I've done with no problems.I hate rude behavior in a man.......Won't tolerate it!                   Woodrow F. Call
GMT+8, 2025-12-25 21:00 , Processed in 0.101364 second(s), 18 queries .
