slag tub
发表于 2021-8-31 23:38:45 | 显示全部楼层 |阅读模式
finally decided to put a tub underneath.its 1/4inch scrapplate and i dont know what the orange piece was but it was all free years ago! a bit overbuilt but itll last. theres a plate that sits on little tabs in the front so you can drop it to clean the tub out.over the winter i found a piece of rail that i cut with a brand new snowblower.had to straighten all the auger blades Attached Imageslincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:Dayam, yup a little overbuilt but here to last tillthe next milllinium at least.  BobI'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys?  Trade?
Reply:Built like the Bismarck!  Although it would be more effective if the burning table it was under had vertical flat bars as opposed to a solid plate with a single hole for the slag to fall through.Last edited by mb_welder; 04-14-2011 at 08:26 PM.
Reply:Agree with both the above, but I really appreciate the "I ain't phuckin' around" of this too!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:ya i thought about the grated design which i also like but decided to go with the bigger opening cause i like not having to put stuff up on bricks or bars to avoid cutting into the grates.works for nowlincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:heres a few pics of the table during its buildup at different times Attached Imageslincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
GMT+8, 2025-12-25 20:59 , Processed in 0.107746 second(s), 18 queries .
