Weld & Machine
发表于 2021-8-31 23:38:44 | 显示全部楼层 |阅读模式
An Accessory drive shaft out of a Cat 6 cyl diesel. An oil seal had worn it down about .020. Attached ImagesI hate rude behavior in a man.......Won't tolerate it!                   Woodrow F. Call
Reply:Hate it when that happens. Attached ImagesI hate rude behavior in a man.......Won't tolerate it!                   Woodrow F. Call
Reply:Okay, what am I missing..................... It appears you tried to repair a worn shaft that was grenaded?!?!http://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:Originally Posted by jackalopeOkay, what am I missing..................... It appears you tried to repair a worn shaft that was grenaded?!?!
Reply:shmutz!
GMT+8, 2025-12-25 17:15 , Processed in 0.097158 second(s), 18 queries .
