Pneumatic Tire casters
发表于 2021-8-31 23:38:38 | 显示全部楼层 |阅读模式
Im looking to make a TIG cart and I'd like to use pneumatic tires/wheels on it.  I'm probably looking at 12" OD for the rear and 6-8" for the front.  I'll need the front to be casters.  Does anyone know of a good supplier online for these and whether or not they exist?  If they don't exist, does anyone have pics of whath theyve built and what type of bearings they've incorporated?I did a google search and came up empty.  Thanks.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:MSChttp://www1.mscdirect.com/eCommerce/...umatic+castersMc MAster Carrhttp://www.mcmaster.com/#pneumatic-w...asters/=kuwy6jGraingershttp://www.grainger.com/Grainger/wwg...n_dim_search=1.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Try tractor supply, im pretty sure ive seen them there.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:thanksTA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Harbor Freight, 10" Pneumatic tire swivel caster, $24.99:http://www.harborfreight.com/10-inch...ter-38944.html- MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:I'd like to know if someone has on idea of what to put in the tires to make them not go flat all the time.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:HF also has 8" casters which I used on my MIG http://www.harborfreight.com/8-inch-...ter-42485.htmlThe rears are 10" HF pneumaticsIt moves very well on my recycled asphalt and gravel driveway.  Which was the reason I used large pneumatics Attached ImagesTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by dumb as a stumpI'd like to know if someone has on idea of what to put in the tires to make them not go flat all the time.
Reply:http://www.castercity.com/casterswnw...%20-%20CastersShipping seems to be a big expense with alot of online vendors, this site is the lowest shipping cost I've found.Last edited by Jwsimpleville; 01-02-2013 at 09:19 PM.
Reply:Originally Posted by DSWOne place I used to work would get heavy equipment tires "foamed" to prevent flats. I've seen foam filled wheel barrow tires also. I'm personally not a big fan of foam filled wheelbarrow tires as they are to "mushy" for my tastes for heavy loads. I haven't really found anything yet that will fill a tire rock hard as if the tires were fully or slightly over inflated.
Reply:second on them getting foamed.    I have a couple of machines on carts with pneumatic wheels and they were a total pain in the *** till i got foamed wheels for themVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Exc for HF, they're all a bit pricier than expected.  I wasn't expecting to spend $200 just on wheels.Sounds like a place where the cheap HF stuff may work.  The wheels wont have a mile on them in my lifetime.Thanks again.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Problem I've had with Great Stuff is that in super thick uses it doesn't dry very well in the center quickly. It's worse in colder temps. I doubt they would be a good choice for this application. It also doesn't tend to "bounce back" when crushed very well.Fully curing has never been an issue with any of the 2 part foams I've tried. The down side is that they are super messy to work with on average. 2 part auto mixers aren't that cheap, though I have started to see more "homeowner" versions available at lower prices..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Any tire shop that does large commercial tires has the tire sealant mentioned by Southpaw. They may give you the remnants left in the bucket so they don't have to pay to get rid of the bucket. Foam filling is pretty expensive for something that is not in a commercial shop or isn't going to be moved a lot.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
Reply:Are you certain you need pneumatic? Unless your rolling this thing on the dirt/gravel/grass a solid tire is better around the shop.They make flat free tires similar to pneumatic but are solid cushy foam. After two flat tires on my wheel barrow in one week I bought a flat free and it's awesome. When this barrow rust out... I'll move the tire to the new one. http://www.globalindustrial.com/p/ma...campaignId=T9L
Reply:Thanks Forhire, those look perfect.I have a cement, blacktop and crushed 3/4" blue amalgam here.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Jwsimplevillehttp://www.castercity.com/casterswnw...%20-%20CastersShipping seems to be a big expense with alot of online vendors, this site is the lowest shipping cost I've found.
GMT+8, 2025-12-25 16:58 , Processed in 0.097745 second(s), 18 queries .
