Pipe Welding. MIG, TIG, or Stick most used?
发表于 2021-8-31 23:38:38 | 显示全部楼层 |阅读模式
Eh. This may be a stupid question and I apologize if it is. What type of welding is mostly used in pipe welding?
Reply:smaw and gtawMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:YupMost black iron carbon steel pipe is stick welded and most stainless steel pipe is tig welded. However, mig welding of pipe is slowly getting more popular.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Depends entirely on what it is used for, Natural gas and oil field is a lot different than say a dairy or restaurant.
Reply:It really depends on the size of the pipe and what the pipe is used for,We used to weld high pressure boiler tubes and the process was an ANSI and ASME procedure which required us to tig our root and cover with a rod and depending on the thickness of the tube/pipe determined how many passes.
Reply:pretty much everybody in the refineries is doing TIG/Stick on carbon steel pipe these days. You hardly ever see a 6010 on a job anymore, unless it's a pipeline.In a fab shop they will do MIG root/DualShield out on a rollout positioner. TIG roots  on position welds
Reply:I weld 6010 everyday on my jobs. And 6010 is used all the time...Miller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:No 6010 in the last 3 refineries I worked in.Chevron - Pascagoula, MSConoco Phillips  - Borger, TXShell - Anacortes, WA.you need a better fit to use 6010, bad gaps and hi-lo are easier to cover up with TIG .I think they like it considering the sad state of affairs regarding the quality of the pipefitters you get nowadays.
GMT+8, 2025-12-25 16:57 , Processed in 0.104254 second(s), 18 queries .
