Hardfacing in the field
发表于 2021-8-31 23:38:37 | 显示全部楼层 |阅读模式
Antbody use 3518 rod for hardfacing? I need to do some buildup a hammermill anvilfor a large wood grinder. The anvils are AR-400 and T1 steel 1" think  and will be stick welding in the field with a gas driven welder. Don.
Reply:What you are looking for is in here.http://www.wbdg.org/ccb/NAVFAC/PPUBB/p433.pdf
Reply:Originally Posted by drp53188Antbody use 3518 rod for hardfacing? I need to do some buildup a hammermill anvilfor a large wood grinder. The anvils are AR-400 and T1 steel 1" think  and will be stick welding in the field with a gas driven welder. Don.
Reply:Thanks for the information, I`ll take a look at it . Iwill get some pics on monday and post them.Last edited by drp53188; 03-14-2010 at 04:13 PM.
GMT+8, 2025-12-25 17:15 , Processed in 0.099518 second(s), 18 queries .
