Lincoln Precision TIG 185 water cooler hook-up
发表于 2021-8-31 23:38:35 | 显示全部楼层 |阅读模式
I have a Lincoln Precision TIG 185 welder and a TIG torch water cooler that I want to set up to run anytime the welder is turned on.  I'm interested in any ideas for accomplishing this with this machine.  I've considered adding relays to power a 115V outlet, but I'm concerned about overcurrent protection for the cooler.  Any one have any expereince running a cooler off of this welder??Thanks,Brycer
GMT+8, 2025-12-25 17:16 , Processed in 0.069684 second(s), 18 queries .
